Introduzione
This is a guide for the removal of the keyboard for an HP HDX 16-1160US. Remember to read each step fully before attempting the repair.
Cosa ti serve
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Remove the three 4mm screws using Phillips #1 screw driver.
Remove the four 6mm screws using Phillips #1 screw driver.
Remove the two 3mm screws using Phillips #1 screw driver.
Altre 2 persone hanno completato questa guida.
2 Commenti
Hello Daniel,
Hoping you might be able to assist me with the similar HDX18 -1000 CTO Premium Notebook / FW314AV Pavilion .
Interested in replacing the LCD inverter board, and would like to confirm where its located and if the HDX 18 has one or two installed.
Your time and any assistance is greatly appreciated, thank you.
Link to HP HDX 16 Entertainment PC Maintenance and Service Guide: Document Part Number: 487263-001;
