Salta al contenuto principale
HP G72 Optical Drive Replacement
Cosa ti serve
  1. HP G72 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 3 HP G72 Optical Drive Replacement, Optical Drive: passo 1, immagine 2 di 3 HP G72 Optical Drive Replacement, Optical Drive: passo 1, immagine 3 di 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
  2. HP G72 Optical Drive Replacement: passo 2, immagine 1 di 3 HP G72 Optical Drive Replacement: passo 2, immagine 2 di 3 HP G72 Optical Drive Replacement: passo 2, immagine 3 di 3
    • Remove the Phillips M2.5x5.0 screw that is identified by the optical disk icon.
    • Pull the optical drive out of its slot.
    • Remove the drive from the computer.
Conclusione
oldturkey03
Membro da: 09/29/10
784.339 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
560 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,470
