Salta al contenuto principale
HP G71t-400 WiFi Card Replacement
Cosa ti serve
  1. HP G71t-400 WiFi Card Replacement, WiFi Card: passo 1, immagine 1 di 3 HP G71t-400 WiFi Card Replacement, WiFi Card: passo 1, immagine 2 di 3 HP G71t-400 WiFi Card Replacement, WiFi Card: passo 1, immagine 3 di 3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 WiFi Card Replacement: passo 2, immagine 1 di 3 HP G71t-400 WiFi Card Replacement: passo 2, immagine 2 di 3 HP G71t-400 WiFi Card Replacement: passo 2, immagine 3 di 3
    • Remove the only circled screw.
    • Lift and remove the cover exposing the WiFi card.
  3. HP G71t-400 WiFi Card Replacement: passo 3, immagine 1 di 1
    • Disconnect the two wires attached. Making note to where each wire was connected for easy install.
    • Extract the WiFi card.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 88
