Salta al contenuto principale
HP G62-234DX Wi-Fi Card Replacement
Cosa ti serve
  1. HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 3 HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 2 di 3 HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 3 di 3
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Wi-Fi Card Replacement: passo 2, immagine 1 di 3 HP G62-234DX Wi-Fi Card Replacement: passo 2, immagine 2 di 3 HP G62-234DX Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
  3. HP G62-234DX Wi-Fi Card Replacement: passo 3, immagine 1 di 3 HP G62-234DX Wi-Fi Card Replacement: passo 3, immagine 2 di 3 HP G62-234DX Wi-Fi Card Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
  4. HP G62-234DX Wi-Fi Card Replacement: passo 4, immagine 1 di 2 HP G62-234DX Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
  5. HP G62-234DX Wi-Fi Card Replacement: passo 5, immagine 1 di 3 HP G62-234DX Wi-Fi Card Replacement: passo 5, immagine 2 di 3 HP G62-234DX Wi-Fi Card Replacement: passo 5, immagine 3 di 3
    • Remove the Wi-Fi card by sliding it out from the socket.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure to be careful when attaching the wires back into the Wi-Fi card, they can be very fragile.
Kate Ferland
Membro da: 11/01/23
836 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 138
