Salta al contenuto principale
HP G62-234DX Hard Drive Replacement
Cosa ti serve
  1. HP G62-234DX Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
  2. HP G62-234DX Hard Drive Replacement: passo 2, immagine 1 di 1
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
  3. HP G62-234DX Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 HP G62-234DX Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 HP G62-234DX Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • It Is recommended to remove the RAM panel for easier access when removing the hard drive panel.
    • Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
    • Use a spudger to remove hard drive panel and carefully lift it up and out.
  4. HP G62-234DX Hard Drive Replacement: passo 4, immagine 1 di 1
    • Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
Conclusione
Cameron Popillo
Membro da: 03/20/23
337 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 98
