Salta al contenuto principale
HP G62-223CL Wireless Card Replacement
Cosa ti serve
  1. HP G62-223CL Wireless Card Replacement, Battery Removal: passo 1, immagine 1 di 2 HP G62-223CL Wireless Card Replacement, Battery Removal: passo 1, immagine 2 di 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Wireless Card Replacement: passo 2, immagine 1 di 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Wireless Card Replacement, Wireless Card: passo 3, immagine 1 di 2 HP G62-223CL Wireless Card Replacement, Wireless Card: passo 3, immagine 2 di 2
    • Locate three Phillips head retaining screws which secure the compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Wireless Card Replacement: passo 4, immagine 1 di 3 HP G62-223CL Wireless Card Replacement: passo 4, immagine 2 di 3 HP G62-223CL Wireless Card Replacement: passo 4, immagine 3 di 3
    • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
  5. HP G62-223CL Wireless Card Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
  6. HP G62-223CL Wireless Card Replacement: passo 6, immagine 1 di 1
    • Carefully lift and pull wireless card. It is removed!
Conclusione
USF Tampa, Team 1-4, Sullivan Winter 2015 Membro di USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,078
