Salta al contenuto principale
HP G62-144DX RAM Replacement
Cosa ti serve
  1. HP G62-144DX RAM Replacement, Battery: passo 1, immagine 1 di 2 HP G62-144DX RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX RAM Replacement, RAM: passo 2, immagine 1 di 3 HP G62-144DX RAM Replacement, RAM: passo 2, immagine 2 di 3 HP G62-144DX RAM Replacement, RAM: passo 2, immagine 3 di 3
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  3. HP G62-144DX RAM Replacement: passo 3, immagine 1 di 3 HP G62-144DX RAM Replacement: passo 3, immagine 2 di 3 HP G62-144DX RAM Replacement: passo 3, immagine 3 di 3
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 328
