Salta al contenuto principale
HP G62-144DX Hard Drive Replacement
Cosa ti serve
  1. HP G62-144DX Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP G62-144DX Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 3 HP G62-144DX Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 3 HP G62-144DX Hard Drive Replacement, Hard Drive: passo 2, immagine 3 di 3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: passo 3, immagine 1 di 3 HP G62-144DX Hard Drive Replacement: passo 3, immagine 2 di 3 HP G62-144DX Hard Drive Replacement: passo 3, immagine 3 di 3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 323
