Salta al contenuto principale
HP G62 347NR Battery Replacement
Cosa ti serve
  1. HP G62 347NR Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery, carefully, from the compartment.
Conclusione
Altre 2 persone hanno completato questa guida.
Texas Tech, Team 6-1, Bennett Fall 2016 Membro di Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 490
