Salta al contenuto principale
HP G60T-600 CTO Power Button Frame Replacement
Cosa ti serve
  1. HP G60T-600 CTO Power Button Frame Replacement, Battery: passo 1, immagine 1 di 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Power Button Frame Replacement: passo 2, immagine 1 di 2 HP G60T-600 CTO Power Button Frame Replacement: passo 2, immagine 2 di 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Power Button Frame Replacement: passo 3, immagine 1 di 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Power Button Frame Replacement, Keyboard: passo 4, immagine 1 di 2 HP G60T-600 CTO Power Button Frame Replacement, Keyboard: passo 4, immagine 2 di 2
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. HP G60T-600 CTO Power Button Frame Replacement: passo 5, immagine 1 di 1
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. HP G60T-600 CTO Power Button Frame Replacement: passo 6, immagine 1 di 1
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A plastic opening tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. HP G60T-600 CTO Power Button Frame Replacement: passo 7, immagine 1 di 2 HP G60T-600 CTO Power Button Frame Replacement: passo 7, immagine 2 di 2
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
  8. HP G60T-600 CTO Power Button Frame Replacement, Power Button Frame: passo 8, immagine 1 di 1
    • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
  9. HP G60T-600 CTO Power Button Frame Replacement: passo 9, immagine 1 di 2 HP G60T-600 CTO Power Button Frame Replacement: passo 9, immagine 2 di 2
    • Gently pull the white tab upwards.
    • With similar force, pull the connection out.
    • You are now free to pull the power button frame off of your device.
  10. HP G60T-600 CTO Power Button Frame Replacement: passo 10, immagine 1 di 1
    • Unscrew the 5mm screw holding the CD player in place.
Conclusione
UMass Dartmouth, Team 4-5, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 145
