Salta al contenuto principale
HP G60T-600 CTO Hard drive Replacement
Cosa ti serve
  1. HP G60T-600 CTO Hard drive Replacement, Battery: passo 1, immagine 1 di 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Hard drive Replacement: passo 2, immagine 1 di 2 HP G60T-600 CTO Hard drive Replacement: passo 2, immagine 2 di 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Hard drive Replacement: passo 3, immagine 1 di 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Hard drive Replacement, Hard drive: passo 4, immagine 1 di 2 HP G60T-600 CTO Hard drive Replacement, Hard drive: passo 4, immagine 2 di 2
    • Remove the 5cm screws with a #00 Phillips screwdriver.
    • Take the cover off.
  5. HP G60T-600 CTO Hard drive Replacement: passo 5, immagine 1 di 3 HP G60T-600 CTO Hard drive Replacement: passo 5, immagine 2 di 3 HP G60T-600 CTO Hard drive Replacement: passo 5, immagine 3 di 3
    • Remove the following .5cm screws with a #0 Phillips screwdriver.
    • Slide the hard drive cover to the right with light-medium force.
  6. HP G60T-600 CTO Hard drive Replacement: passo 6, immagine 1 di 1
    • Pull up on the little black tab on the hard drive case to remove it.
    • From here you will be able to carefully slide your hard drive out.
Conclusione
UMass Dartmouth, Team 4-5, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 165
