Salta al contenuto principale
HP G60-443CL Battery Replacement
Cosa ti serve
  1. HP G60-443CL Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Battery Replacement: passo 2, immagine 1 di 1
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Battery Replacement: passo 3, immagine 1 di 1
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Battery Replacement: passo 4, immagine 1 di 1
    • The battery can then be pulled out of its compartment by hand.
Conclusione
Alora Allen
Membro da: 11/06/17
101 Reputazione
1 Guida realizzata
Baylor, Team S8-G7, Johnson Fall 2017 Membro di Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 309
