Salta al contenuto principale
HP G60 RAM Replacement
Cosa ti serve
  1. HP G60 RAM Replacement, Battery: passo 1, immagine 1 di 3 HP G60 RAM Replacement, Battery: passo 1, immagine 2 di 3 HP G60 RAM Replacement, Battery: passo 1, immagine 3 di 3
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
  2. HP G60 RAM Replacement, RAM cover: passo 2, immagine 1 di 3 HP G60 RAM Replacement, RAM cover: passo 2, immagine 2 di 3 HP G60 RAM Replacement, RAM cover: passo 2, immagine 3 di 3
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
  3. HP G60 RAM Replacement, Eject RAM: passo 3, immagine 1 di 3 HP G60 RAM Replacement, Eject RAM: passo 3, immagine 2 di 3 HP G60 RAM Replacement, Eject RAM: passo 3, immagine 3 di 3
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
  4. HP G60 RAM Replacement, New RAM: passo 4, immagine 1 di 3 HP G60 RAM Replacement, New RAM: passo 4, immagine 2 di 3 HP G60 RAM Replacement, New RAM: passo 4, immagine 3 di 3
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
  5. HP G60 RAM Replacement, RAM cover (Again): passo 5, immagine 1 di 3 HP G60 RAM Replacement, RAM cover (Again): passo 5, immagine 2 di 3 HP G60 RAM Replacement, RAM cover (Again): passo 5, immagine 3 di 3
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
Linea Traguardo
Altre 5 persone hanno completato questa guida.
jimenezser
Membro da: 08/29/12
3.848 Reputazione
4 Guide realizzate
Un commento
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 6,042
