Introduzione
Make sure you have completed the keyboard replacement guide and the top cover removal guide.
A defective heat sink can cause your laptop's CPU to overheat. This guide will show you how to correctly replace the heat sink for your HP Folio 13t-1000.
Cosa ti serve
Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
Do the same for the second connection.
