Salta al contenuto principale
HP Folio 13t-1000 Heatsink Replacement
Cosa ti serve
  1. HP Folio 13t-1000 Heatsink Replacement, Keyboard: passo 1, immagine 1 di 2 HP Folio 13t-1000 Heatsink Replacement, Keyboard: passo 1, immagine 2 di 2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Heatsink Replacement: passo 2, immagine 1 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 2, immagine 2 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 2, immagine 3 di 3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Heatsink Replacement: passo 3, immagine 1 di 1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Heatsink Replacement: passo 4, immagine 1 di 2 HP Folio 13t-1000 Heatsink Replacement: passo 4, immagine 2 di 2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Heatsink Replacement: passo 5, immagine 1 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 5, immagine 2 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 5, immagine 3 di 3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Heatsink Replacement: passo 6, immagine 1 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 6, immagine 2 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 6, immagine 3 di 3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: passo 7, immagine 1 di 3 HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: passo 7, immagine 2 di 3 HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: passo 7, immagine 3 di 3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Heatsink Replacement: passo 8, immagine 1 di 2 HP Folio 13t-1000 Heatsink Replacement: passo 8, immagine 2 di 2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Heatsink Replacement, Heat Sink: passo 9, immagine 1 di 2 HP Folio 13t-1000 Heatsink Replacement, Heat Sink: passo 9, immagine 2 di 2
    • Use a PH1 screw head to take out the four, 2mm screws.
  10. HP Folio 13t-1000 Heatsink Replacement: passo 10, immagine 1 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 10, immagine 2 di 3 HP Folio 13t-1000 Heatsink Replacement: passo 10, immagine 3 di 3
    • Remove the heatsink with you fingers and replace it with a new heatsink.
Conclusione
USF Tampa, Team 1-2, Cagle Fall 2016 Membro di USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 229
