Introduzione
Random Access Memory (RAM) is essential because it temporarily carries software and memorize in current use. It allows the processor to access data much faster and mor efficient, compared to a hard drive or solid state drive.
HP Envy x360 m6-w105dx has 8GB DDR3L SDRAM (1 DIMM).
This guide page will provide instructions for dealing with RAM problem and replacing RAM.
Cosa ti serve
Use the opening pick to lift up the eight rubber grips on the underside of the device.
With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
Gently open the ZIF connectors and remove the ribbon cables.
Unscrew the five 4mm screws with the Phillips #1 screwdriver.
Unscrew the WLAN chip and push the chip up and out of the port.
Altre 3 persone hanno completato questa guida.
Un commento
this is the first time i’ve been on the ifixit site but thanks to my google search of this topic, I found this and it is extremely simple and helpful. I haven’t actually done this yet but am confident I can once I get the replacement ram. I need my laptop to be a portable video editing work station and the stock ram on these will run premiere pro, just very very slowly.
