Salta al contenuto principale
HP Envy x360 m6-w101dx Fan Replacement
Cosa ti serve
  1. HP Envy x360 m6-w101dx Fan Replacement, Keyboard Panel: passo 1, immagine 1 di 1
    • Place the laptop so that the bottom panel is facing upwards.
  2. HP Envy x360 m6-w101dx Fan Replacement: passo 2, immagine 1 di 3 HP Envy x360 m6-w101dx Fan Replacement: passo 2, immagine 2 di 3 HP Envy x360 m6-w101dx Fan Replacement: passo 2, immagine 3 di 3
    • Remove the screw covers using an iFixit opening tool.
  3. HP Envy x360 m6-w101dx Fan Replacement: passo 3, immagine 1 di 1
    • Remove twelve 8 mm Phillips #1 screws.
  4. HP Envy x360 m6-w101dx Fan Replacement: passo 4, immagine 1 di 3 HP Envy x360 m6-w101dx Fan Replacement: passo 4, immagine 2 di 3 HP Envy x360 m6-w101dx Fan Replacement: passo 4, immagine 3 di 3
    • Pry open a gap in the edge of the keyboard with an iFixit opening tool.
  5. HP Envy x360 m6-w101dx Fan Replacement: passo 5, immagine 1 di 1
    • Remove the keyboard from the laptop.
  6. HP Envy x360 m6-w101dx Fan Replacement, Fan: passo 6, immagine 1 di 1
    • Remove the five 4.5mm Phillips #1 screws surrounding the fan.
  7. HP Envy x360 m6-w101dx Fan Replacement: passo 7, immagine 1 di 1
    • Remove the three 4.5mm Phillips #1 screws from right side of the motherboard.
  8. HP Envy x360 m6-w101dx Fan Replacement: passo 8, immagine 1 di 1
    • Detach the cable between the CPU and the motherboard.
  9. HP Envy x360 m6-w101dx Fan Replacement: passo 9, immagine 1 di 1
    • Detach the cable between the battery and the motherboard.
  10. HP Envy x360 m6-w101dx Fan Replacement: passo 10, immagine 1 di 1
    • Disconnect the cable between the SD card and the motherboard.
  11. HP Envy x360 m6-w101dx Fan Replacement: passo 11, immagine 1 di 1
    • Disconnect the cable between the screen and the motherboard.
  12. HP Envy x360 m6-w101dx Fan Replacement: passo 12, immagine 1 di 1
    • Detach the connection between the fan and the motherboard.
  13. HP Envy x360 m6-w101dx Fan Replacement: passo 13, immagine 1 di 1
    • Disconnect the cable from the speaker to the motherboard.
  14. HP Envy x360 m6-w101dx Fan Replacement: passo 14, immagine 1 di 1
    • Disconnect the cable between the CPU and the power interface.
  15. HP Envy x360 m6-w101dx Fan Replacement: passo 15, immagine 1 di 1
    • Turn the connected motherboard and fan upside down and remove the four 4.5mm Phillips #1 screws from the middle of the back of the motherboard.
  16. HP Envy x360 m6-w101dx Fan Replacement: passo 16, immagine 1 di 1
    • Disconnect the cable connecting the fan to the motherboard.
  17. HP Envy x360 m6-w101dx Fan Replacement: passo 17, immagine 1 di 1
    • Remove the fan from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 676
