Salta al contenuto principale
HP Envy x360 m6-aq105dx Battery Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq105dx Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Battery Replacement: passo 2, immagine 1 di 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the power supply cable connected to the motherboard.
  5. HP Envy x360 m6-aq105dx Battery Replacement: passo 5, immagine 1 di 2 HP Envy x360 m6-aq105dx Battery Replacement: passo 5, immagine 2 di 2
    • Remove the battery from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,144
