Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide is for the replacement of the Wireless Module. You will need a small plastic opening tool and a standard Phillips Head 1 Screwdriver.
  1. Flip the laptop over to expose the underside. Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up. The grip pads are tacky, remove slowly to avoid separating the adhesive.
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right. You may hear a slight clicking or popping, but that is normal. You may hear a slight clicking or popping, but that is normal.
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws. Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool. Lift up the port with the tool. Lift up the port with the tool.
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. Lift the battery out of the laptop with your hands. Lift the battery out of the laptop with your hands. Lift the battery out of the laptop with your hands.
    • Lift the battery out of the laptop with your hands.
  8. Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up. Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up. Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
    • Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
  9. Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
    • Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
  10. Slide the wireless module towards the back of the computer to remove it. Slide the wireless module towards the back of the computer to remove it. Slide the wireless module towards the back of the computer to remove it.
    • Slide the wireless module towards the back of the computer to remove it.
Conclusione
Joey Chen
Membro da: 02/10/2017
292 Reputazione
2 Guide realizzate
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro di Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Membri
9 Guide realizzate
@jchen202 Just curious, what is the Battery Wattage of this HP Envy? I noticed your guide contains a glimpse of the DC IN CONNECTOR , which seems to be identical to my HP ENVY X360 - 15M-BP112DX. How idid your repairs turn out? If possible, would you be able to provide a picture of the DC IN Connector?
Al N - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 686
