Salta al contenuto principale
HP Envy x360 m6-aq103dx Motherboard Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq103dx Motherboard Replacement, Bottom Cover: passo 1, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Bottom Cover: passo 1, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 4, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 4, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 4, immagine 3 di 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Motherboard Replacement, Battery: passo 5, immagine 1 di 2 HP Envy x360 m6-aq103dx Motherboard Replacement, Battery: passo 5, immagine 2 di 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 6, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 6, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 6, immagine 3 di 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 7, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 7, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 7, immagine 3 di 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Motherboard Replacement, Headphone Jack: passo 8, immagine 1 di 2 HP Envy x360 m6-aq103dx Motherboard Replacement, Headphone Jack: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Make sure you are wearing an anti-static wrist strap.
    • Remove the four screws from the blue board that contains the headphone jack using the Phillips head 1 screwdriver (one 4 mm black screw, one 3 mm black screw, and two 4.5 mm silver screws).
  9. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 9, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 9, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 9, immagine 3 di 3
    • Insert the plastic opening tool underneath the connector on the black flexible flat cable with the blue plastic stripe.
    • Lift the opening tool to open the connector.
    • Use your fingers to slide the ribbon cable out of the connector.
  10. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 10, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 10, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 10, immagine 3 di 3
    • Hold the left side of the board between your fingers.
    • Lift the edge upwards enough to clear the other components in the way.
    • Be gentle when lifting to avoid breaking the board.
    • Slide and rotate to lift the board out of the designated slot for the board.
    • You may have to wiggle the board back and forth, and up and down, to remove the board.
  11. HP Envy x360 m6-aq103dx Motherboard Replacement, Intel Wireless Module: passo 11, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Intel Wireless Module: passo 11, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Intel Wireless Module: passo 11, immagine 3 di 3
    • Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
  12. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
  13. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 13, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 13, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 13, immagine 3 di 3
    • Slide the wireless module towards the back of the computer to remove it.
  14. HP Envy x360 m6-aq103dx Motherboard Replacement, Hard Drive: passo 14, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Hard Drive: passo 14, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Hard Drive: passo 14, immagine 3 di 3
    • Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
    • Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
  15. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 15, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 15, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 15, immagine 3 di 3
    • Remove the two Phillips head screws (5 mm) using the Phillip's head #1 screwdriver.
    • Use your hands to lift the hard drive up and remove it.
  16. HP Envy x360 m6-aq103dx Motherboard Replacement, RAM: passo 16, immagine 1 di 2 HP Envy x360 m6-aq103dx Motherboard Replacement, RAM: passo 16, immagine 2 di 2
    $7.95
  17. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 17, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 17, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 17, immagine 3 di 3
    • Pull the two outer pins on either side of the ram chip outward with your hands.
    • The ram chips should pop up.
    • Do this for both chips.
  18. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 18, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 18, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 18, immagine 3 di 3
    • Remove the chips one at a time, by sliding them towards the side of the computer they are pointing towards.
  19. HP Envy x360 m6-aq103dx Motherboard Replacement, Motherboard: passo 19, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Motherboard: passo 19, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement, Motherboard: passo 19, immagine 3 di 3
    • Use the small plastic opening tool to disconnect the port attached to the white ribbon cable with purple tips.
    • Press the tool to the top of the tip of the cable and pull it outwards.
    • Press the tool to the side of the tip of the cable and slide it outwards.
    • Use your hand to lift the cable up and out of the way.
  20. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 20, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 20, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 20, immagine 3 di 3
    • Use the small plastic opening tool to disconnect the port attached to the blue ribbon cable with a black stripe.
  21. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 21, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 21, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 21, immagine 3 di 3
    • Use the small plastic opening tool to disconnect the port attached to the golden brown ribbon cable with the yellow underside.
  22. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 22, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 22, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 22, immagine 3 di 3
    • Remove the clear tape near the charging port with your hand in order to flip the tab up with the small plastic opening tool.
  23. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 23, immagine 1 di 2 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 23, immagine 2 di 2
    • Remove the wire with the green plastic tape from between the motherboard and the black hinge using your hand by puling it backwards.
  24. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 24, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 24, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 24, immagine 3 di 3
    • Remove the wire by the blue ribbon cable using your hands.
  25. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 25, immagine 1 di 1
    • Using the Phillips head #1 screwdriver remove the five 4.5 mm grey screws.
    • Using the Phillips head #1 screwdriver remove the two 2.5 mm black screws.
  26. HP Envy x360 m6-aq103dx Motherboard Replacement: passo 26, immagine 1 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 26, immagine 2 di 3 HP Envy x360 m6-aq103dx Motherboard Replacement: passo 26, immagine 3 di 3
    • Using your hand, gently lift up the motherboard to remove it.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro di Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Membri
9 Guide realizzate
4 Commenti
how to replace the keyboard?
javier hdez - Replica
need a solder gun?
Hi, great post. good pics and details. The only thing you missed was removal of the CPU cooling fan, but that was pretty easy to figure out once into it that far. Thanks!
Joe - Replica
What are the newer motherboards I can upgrade this laptop with ? please advise.
Nuwan Dank - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 5,551
