Introduzione
This is a simple guide to replace the headphone jack if it is loose or broken. You will need an anti-static wristband, a Philips head 1 screwdriver, and a blue nylon opening tool to complete this replacement guide.
Cosa ti serve
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Make sure you are wearing an anti-static wrist strap.
Remove the four screws from the blue board that contains the headphone jack using the Phillips head 1 screwdriver (one 4 mm black screw, one 3 mm black screw, and two 4.5 mm silver screws).
