Salta al contenuto principale
HP Envy x360 m6-aq103dx Bottom Cover Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: passo 1, immagine 2 di 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: passo 2, immagine 1 di 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Bottom Cover Replacement: passo 3, immagine 1 di 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Bottom Cover Replacement: passo 4, immagine 1 di 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: passo 4, immagine 2 di 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: passo 4, immagine 3 di 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro di Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Membri
9 Guide realizzate
4 Commenti
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Joshua Bowman - Replica
It was really easy to open.
[deleted] - Replica
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
MrHarris73 - Replica
But where can i purchase the bottom cover
imran abdulhameed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 8,757
