Salta al contenuto principale
HP Envy x360 m6-aq103dx Battery Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: passo 1, immagine 1 di 3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: passo 1, immagine 2 di 3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Battery Replacement: passo 2, immagine 1 di 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Battery Replacement: passo 3, immagine 1 di 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Battery Replacement: passo 4, immagine 1 di 3 HP Envy x360 m6-aq103dx Battery Replacement: passo 4, immagine 2 di 3 HP Envy x360 m6-aq103dx Battery Replacement: passo 4, immagine 3 di 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Battery Replacement, Battery: passo 5, immagine 1 di 2 HP Envy x360 m6-aq103dx Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Battery Replacement: passo 6, immagine 1 di 3 HP Envy x360 m6-aq103dx Battery Replacement: passo 6, immagine 2 di 3 HP Envy x360 m6-aq103dx Battery Replacement: passo 6, immagine 3 di 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Battery Replacement: passo 7, immagine 1 di 3 HP Envy x360 m6-aq103dx Battery Replacement: passo 7, immagine 2 di 3 HP Envy x360 m6-aq103dx Battery Replacement: passo 7, immagine 3 di 3
    • Lift the battery out of the laptop with your hands.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro di Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 7,395
