Salta al contenuto principale
HP Envy x360 m6-aq005dx Keyboard Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Use the Phillips #0 screw driver head to remove the two 7.8mm screws that secure the bottom cover to the computer.
    • Use the Phillips #00 screw driver head to remove the six 5.2mm screws that secure the bottom cover to the computer.
    • Insert the iFixit plastic prying tool between the bottom cover and bottom chassis.
    • Lift the cover carefully off the machine.
  2. HP Envy x360 m6-aq005dx Keyboard Replacement: passo 2, immagine 1 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 2, immagine 2 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #00 screw driver head to remove the six 4.6mm screws that secure the battery to the top cover.
    • Disconnect the battery cable from the motherboard.
    • Lift to remove the battery and set it to the side.
  3. HP Envy x360 m6-aq005dx Keyboard Replacement: passo 3, immagine 1 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 3, immagine 2 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 3, immagine 3 di 3
    • Use the Phillips #00 screw driver head to remove the three 4.6mm screws that secure the fan to the top cover.
    • Release the display panel cable from the retention clips and channel built into the fan.
    • Use the Phillips #0 screw driver head to remove the four 6.2mm captive screws that secure the fan/ heat sink assembly to the motherboard.
    • Remove the fan/heat sink assembly.
  4. HP Envy x360 m6-aq005dx Keyboard Replacement: passo 4, immagine 1 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 4, immagine 2 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 4, immagine 3 di 3
    • Use the Phillips #00 screw driver head to remove the following screws that secure the motherboard to the top cover:
    • Four 4.6mm screws;
    • Two 3.3 mm screws.
    • Use the Phillips #0 screw driver head to remove the one 4.5mm screw that secure the system board to the top cover.
    • Use the iFixit plastic prying tool to disconnect the seven marked data cables linked to the system board.
    • Lift the motherboard to remove it from the top cover.
  5. HP Envy x360 m6-aq005dx Keyboard Replacement: passo 5, immagine 1 di 2 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 5, immagine 2 di 2
    • Use the Phillips #00 screw driver head to remove the three 4.6mm screws that secure the hard drive to the top cover.
    • Remove the hard drive.
  6. HP Envy x360 m6-aq005dx Keyboard Replacement: passo 6, immagine 1 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 6, immagine 2 di 3 HP Envy x360 m6-aq005dx Keyboard Replacement: passo 6, immagine 3 di 3
    • Use the Phillips #0 screw driver head to remove the six 4.5mm screws that secure the display assembly to the keyboard/ top cover.
    • Use the Phillips #00 screw driver head to remove the three 3.3mm screw that secure the connector board to the keyboard/top cover then remove the connector board.
    • Replace the keyboard.
Conclusione
Bo Sun
Membro da: 10/08/16
162 Reputazione
1 Guida realizzata
IUPUI, Team S4-G4, Wilson Fall 2019 Membro di IUPUI, Team S4-G4, Wilson Fall 2019
IUPUI-WILSON-F19S4G4
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 927
