Salta al contenuto principale
HP Envy x360 m6-aq005dx Battery Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: passo 1, immagine 1 di 2 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: passo 2, immagine 1 di 3 HP Envy x360 m6-aq005dx Battery Replacement: passo 2, immagine 2 di 3 HP Envy x360 m6-aq005dx Battery Replacement: passo 2, immagine 3 di 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: passo 4, immagine 1 di 2 HP Envy x360 m6-aq005dx Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team S13-G17, Cagle Fall 2017 Membro di USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Membri
7 Guide realizzate
3 Commenti
Step 3 was the toughest!!! Case was difficult to separate.
Bo Hagen - Replica
Thank you!!!! This made it sooooo easy to replace my battery!
Michelle Kuhlmann - Replica
Excellent guide, many thanks for posting it.
stephenm.race - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 33
Tutti i Tempi: 15,592
