Salta al contenuto principale
HP Envy x360 m6-aq005dx Back Panel Replacement
Cosa ti serve
  1. HP Envy x360 m6-aq005dx Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 HP Envy x360 m6-aq005dx Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Back Panel Replacement: passo 2, immagine 1 di 3 HP Envy x360 m6-aq005dx Back Panel Replacement: passo 2, immagine 2 di 3 HP Envy x360 m6-aq005dx Back Panel Replacement: passo 2, immagine 3 di 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Back Panel Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
Conclusione
USF Tampa, Team S13-G17, Cagle Fall 2017 Membro di USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,528
