Salta al contenuto principale
HP Envy x360 15m-cn0012dx Daughterboard Replacement
Cosa ti serve
  1. HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: passo 1, immagine 1 di 2 HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: passo 1, immagine 2 di 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 2, immagine 1 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 2, immagine 2 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 3, immagine 1 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 3, immagine 2 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 3, immagine 3 di 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 4, immagine 1 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 4, immagine 2 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 4, immagine 3 di 3
    • Use the iFixit opening tool to unlatch the ZIF connector with the cable labelled 'SD' from the daughterboard.
    • Slide out the interconnect ribbon cable.
  5. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 5, immagine 1 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 5, immagine 2 di 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 5, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove the two 4mm screws on holding down the SD card daughterboard.
    • Remove the SD card daughterboard.
Conclusione
Grace Daleki
Membro da: 02/04/20
487 Reputazione
3 Guide realizzate
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Membro di UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 722
