Salta al contenuto principale
HP Envy x360 15m-bq021dx Speakers Replacement
Cosa ti serve
  1. HP Envy x360 15m-bq021dx Speakers Replacement, Battery: passo 1, immagine 1 di 2 HP Envy x360 15m-bq021dx Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Speakers Replacement: passo 2, immagine 1 di 3 HP Envy x360 15m-bq021dx Speakers Replacement: passo 2, immagine 2 di 3 HP Envy x360 15m-bq021dx Speakers Replacement: passo 2, immagine 3 di 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Speakers Replacement: passo 3, immagine 1 di 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Speakers Replacement: passo 4, immagine 1 di 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Speakers Replacement: passo 5, immagine 1 di 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Speakers Replacement, Cooling Fan: passo 6, immagine 1 di 2 HP Envy x360 15m-bq021dx Speakers Replacement, Cooling Fan: passo 6, immagine 2 di 2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Speakers Replacement: passo 7, immagine 1 di 2 HP Envy x360 15m-bq021dx Speakers Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Speakers Replacement: passo 8, immagine 1 di 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Speakers Replacement: passo 9, immagine 1 di 2 HP Envy x360 15m-bq021dx Speakers Replacement: passo 9, immagine 2 di 2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Speakers Replacement, Motherboard: passo 10, immagine 1 di 3 HP Envy x360 15m-bq021dx Speakers Replacement, Motherboard: passo 10, immagine 2 di 3 HP Envy x360 15m-bq021dx Speakers Replacement, Motherboard: passo 10, immagine 3 di 3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Speakers Replacement: passo 11, immagine 1 di 3 HP Envy x360 15m-bq021dx Speakers Replacement: passo 11, immagine 2 di 3 HP Envy x360 15m-bq021dx Speakers Replacement: passo 11, immagine 3 di 3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Speakers Replacement: passo 12, immagine 1 di 2 HP Envy x360 15m-bq021dx Speakers Replacement: passo 12, immagine 2 di 2
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Speakers Replacement, Speakers: passo 13, immagine 1 di 1
    • Use the tweezers to remove the cords from their restraints.
    • Lift the speakers out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 507
