Salta al contenuto principale
HP Envy x360 15m-bq021dx RAM Replacement
Cosa ti serve
  1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: passo 1, immagine 1 di 2 HP Envy x360 15m-bq021dx RAM Replacement, Battery: passo 1, immagine 2 di 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx RAM Replacement: passo 2, immagine 1 di 3 HP Envy x360 15m-bq021dx RAM Replacement: passo 2, immagine 2 di 3 HP Envy x360 15m-bq021dx RAM Replacement: passo 2, immagine 3 di 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx RAM Replacement: passo 3, immagine 1 di 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx RAM Replacement: passo 4, immagine 1 di 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx RAM Replacement: passo 5, immagine 1 di 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx RAM Replacement, RAM: passo 6, immagine 1 di 1
    • Remove the tape near the RAM storage.
  7. HP Envy x360 15m-bq021dx RAM Replacement: passo 7, immagine 1 di 2 HP Envy x360 15m-bq021dx RAM Replacement: passo 7, immagine 2 di 2
    • Use a small blue opening tool to pry open the protective metal cover.
  8. HP Envy x360 15m-bq021dx RAM Replacement: passo 8, immagine 1 di 1
    • Pull on the silver pins away from the RAM on both sides.
  9. HP Envy x360 15m-bq021dx RAM Replacement: passo 9, immagine 1 di 2 HP Envy x360 15m-bq021dx RAM Replacement: passo 9, immagine 2 di 2
    • Pull the RAM up and out to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,867
