Salta al contenuto principale
HP Envy x360 15m-bp111dx Hard Drive Replacement
Cosa ti serve
  1. HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 2 HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 2, immagine 1 di 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 2, immagine 2 di 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 2, immagine 3 di 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: passo 3, immagine 1 di 2 HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: passo 3, immagine 2 di 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 4, immagine 1 di 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 4, immagine 2 di 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 4, immagine 3 di 3
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • The hard drive bay is located in the lower left corner of the computer.
    • The hard drive will be covered by a black rubber sheath which can be removed by simply pulling it off of the hard drive (not pictured).
  6. HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 6, immagine 1 di 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 6, immagine 2 di 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 6, immagine 3 di 3
    • Pull the rubber casing away from the drive (not pictured here) and gently lift the hard drive out of the computer.
    • Unplug the drive from power by grabbing the SATA / power cable on the plastic edge and pulling it away from the drive.
    • Do not disconnect the ribbon cable from the motherboard.
  7. HP Envy x360 15m-bp111dx Hard Drive Replacement: passo 7, immagine 1 di 1
    • The hard drive is now removed and can be replaced.
Conclusione
Ross Snead
Membro da: 02/22/22
162 Reputazione
1 Guida realizzata
Clemson, Team 2-2, Hunter Spring 2022 Membro di Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 430
