Introduzione
This replacement guide will assist in locating, removing, and replacing the lithium-ion battery of your HP Envy x360 15m-bp111dx. You may need to utilize this guide if your battery is dead or faulty. Additionally, this guide may be helpful if your laptop is hot to the touch.
Before beginning this replacement, please be sure that your laptop is powered off, disconnected from the power adapter, and that the components have cooled down.
More troubleshooting information for the battery is included in our troubleshooting guide here.
Cosa ti serve
Remove the rubber feet to access the screws.
Using a Phillips #0 screwdriver, remove the four 7 mm screws.
Using a T5 Torx screwdriver, remove the three 5 mm screws.
Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
