Introduzione
RAM can wear over time leading to blue screen of death, corrupt files, and other issues. In addition, faulty RAM may lead to slower computer loading times and can affect the overall performance of a computer. If you’re looking to replace or upgrade the RAM in your device, use the steps in this guide to replace the RAM in your laptop.
Cosa ti serve
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
Remove the five 4mm screws with the Phillips #0 screwdriver.
Remove one 3mm screw with the Phillips #00 screwdriver.
Use both fingers to push the tabs to the side and release the RAM.
Remove the RAM chip by pulling away from the connector.
