Salta al contenuto principale
HP Envy x360 15-bp143cl Motherboard Replacement
Cosa ti serve
  1. HP Envy x360 15-bp143cl Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Motherboard Replacement: passo 5, immagine 1 di 2 HP Envy x360 15-bp143cl Motherboard Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Peel off the tape securing the heatsink.
  8. HP Envy x360 15-bp143cl Motherboard Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the seven 4 mm screws securing the fan.
    • Detach the fan cable from the mother board.
  9. HP Envy x360 15-bp143cl Motherboard Replacement: passo 9, immagine 1 di 1
    • Lift the fan up and off the motherboard.
  10. HP Envy x360 15-bp143cl Motherboard Replacement: passo 10, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the ten 4 mm screws securing the motherboard.
    • Pull the four cables directly out of their ports.
    • Flip up the lock-bar on the two ZIF connectors, then gently pull the two ribbon cables directly out of their ports.
  11. HP Envy x360 15-bp143cl Motherboard Replacement: passo 11, immagine 1 di 1
    • Gently lift the motherboard up and out of the chassis.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 804
