Salta al contenuto principale
HP Envy x360 15-bp143cl Hard Drive Replacement
Cosa ti serve
  1. HP Envy x360 15-bp143cl Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 5, immagine 1 di 2 HP Envy x360 15-bp143cl Hard Drive Replacement: passo 5, immagine 2 di 2
    • Lift the black tab securing the hard drive connecting cable to the laptop to remove the cable.
  6. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 6, immagine 1 di 1
    • Lift the hard drive from its slot.
    • If the hard drive is attached using adhesive, use an opening tool to pry it from the laptop.
Conclusione
Cal Poly, Team S12-G3, Regan Fall 2019 Membro di Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
3 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,235
