Introduzione
When your daughterboard crashes you do not have to settle for a slow functioning system, when you can replace it. In this guide I will show you how to replace the daughterboard with these detailed steps. As long as you follow my guide step by step and have the tools needed, this repair will have your HP Envy back to the enhanced functioning system you once had. Please be cautions and make sure the battery is drained before fixing as it is a fire hazard if not.
Cosa ti serve
Use a Phillips #1 screwdriver to remove the single 4 mm screw securing the daughterboard.
Disconnect the ribbon cable.
