Introduzione
In this guide, you will learn how to remove the hard drive in order to either replace, upgrade, or manage the hard drive.
Cosa ti serve
Remove the cable connecting the hard drive to the motherboard by carefully lifting the black tab, then pulling out the disconnected ribbon cable.
Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
Lift directly up to remove the main speaker.
Gently pull the wire out of the plastic track that it's set in.
There are wires over some of the screws, use a thin implement to get the wires out of their track.
Unplug the SATA cable from the motherboard (covered in the teardown for the battery).
Remove the 4 screws
Remove the Hard drive from the unit
Un commento
Thanks for this guide. It really helped out and drastically sped up the whole process.
I needed to install a 2.5" SSD and new RAM to my girlfriend's machine and have never opened up a HP laptop.
Appreciate all the effort that went in to this!
