Salta al contenuto principale
HP Envy m6-n010dx Speaker Replacement
Cosa ti serve
  1. HP Envy m6-n010dx Speaker Replacement, Battery: passo 1, immagine 1 di 3 HP Envy m6-n010dx Speaker Replacement, Battery: passo 1, immagine 2 di 3 HP Envy m6-n010dx Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Speaker Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Speaker Replacement: passo 3, immagine 1 di 2 HP Envy m6-n010dx Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Speaker Replacement: passo 4, immagine 1 di 3 HP Envy m6-n010dx Speaker Replacement: passo 4, immagine 2 di 3 HP Envy m6-n010dx Speaker Replacement: passo 4, immagine 3 di 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Speaker Replacement, Speaker: passo 5, immagine 1 di 3 HP Envy m6-n010dx Speaker Replacement, Speaker: passo 5, immagine 2 di 3 HP Envy m6-n010dx Speaker Replacement, Speaker: passo 5, immagine 3 di 3
    • Remove the marked screws.
    • Pry off the lower two grip pads.
    • You may need to use more force than feels necessary.
    • Remove the two additional screws underneath the lower grip pads.
    • Remove the large back panel to reveal the inner workings.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Speaker Replacement: passo 6, immagine 1 di 3 HP Envy m6-n010dx Speaker Replacement: passo 6, immagine 2 di 3 HP Envy m6-n010dx Speaker Replacement: passo 6, immagine 3 di 3
    • Locate the speaker.
    • Locate the tape on the speaker.
    • Peel back the tape, disconnecting it from the speaker.
    • When reassembling the speaker, make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Speaker Replacement: passo 7, immagine 1 di 3 HP Envy m6-n010dx Speaker Replacement: passo 7, immagine 2 di 3 HP Envy m6-n010dx Speaker Replacement: passo 7, immagine 3 di 3
    • Locate the connecting wire attached to the speaker.
    • Disconnect the wire.
  8. HP Envy m6-n010dx Speaker Replacement: passo 8, immagine 1 di 2 HP Envy m6-n010dx Speaker Replacement: passo 8, immagine 2 di 2
    • Use a screwdriver to unscrew the three screws on the speaker.
  9. HP Envy m6-n010dx Speaker Replacement: passo 9, immagine 1 di 3 HP Envy m6-n010dx Speaker Replacement: passo 9, immagine 2 di 3 HP Envy m6-n010dx Speaker Replacement: passo 9, immagine 3 di 3
    • Remove the speaker.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 278
