Salta al contenuto principale
HP Envy m6-n010dx Hard Drive Replacement
Cosa ti serve
  1. HP Envy m6-n010dx Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 HP Envy m6-n010dx Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 HP Envy m6-n010dx Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Hard Drive Replacement: passo 3, immagine 1 di 2 HP Envy m6-n010dx Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Hard Drive Replacement: passo 4, immagine 1 di 3 HP Envy m6-n010dx Hard Drive Replacement: passo 4, immagine 2 di 3 HP Envy m6-n010dx Hard Drive Replacement: passo 4, immagine 3 di 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,288
