Salta al contenuto principale
Introduzione
This guide demonstrates how to properly remove the fan of a HP Envy m6-n010dx. You will be using a Phillips 00 screwdriver throughout this guide.
  1. HP Envy m6-n010dx Fan Replacement, Battery: passo 1, immagine 1 di 3 HP Envy m6-n010dx Fan Replacement, Battery: passo 1, immagine 2 di 3 HP Envy m6-n010dx Fan Replacement, Battery: passo 1, immagine 3 di 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Fan Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Fan Replacement: passo 3, immagine 1 di 2 HP Envy m6-n010dx Fan Replacement: passo 3, immagine 2 di 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Fan Replacement: passo 4, immagine 1 di 3 HP Envy m6-n010dx Fan Replacement: passo 4, immagine 2 di 3 HP Envy m6-n010dx Fan Replacement: passo 4, immagine 3 di 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Fan Replacement, Fan: passo 5, immagine 1 di 3 HP Envy m6-n010dx Fan Replacement, Fan: passo 5, immagine 2 di 3 HP Envy m6-n010dx Fan Replacement, Fan: passo 5, immagine 3 di 3
    • Remove the screws highlighted in red
    • Pry off with prying tool the lower two grip pads highlighted in orange
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Fan Replacement: passo 6, immagine 1 di 3 HP Envy m6-n010dx Fan Replacement: passo 6, immagine 2 di 3 HP Envy m6-n010dx Fan Replacement: passo 6, immagine 3 di 3
    • Locate fan
    • Gently remove tape that hold the heatsink and fan together
    • When reassembling , make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Fan Replacement: passo 7, immagine 1 di 3 HP Envy m6-n010dx Fan Replacement: passo 7, immagine 2 di 3 HP Envy m6-n010dx Fan Replacement: passo 7, immagine 3 di 3
    • Loosen the four screws on the heat sink indicated in picture
    • Remove the heatsink
  8. HP Envy m6-n010dx Fan Replacement: passo 8, immagine 1 di 2 HP Envy m6-n010dx Fan Replacement: passo 8, immagine 2 di 2
    • Gently disconnect the wire connecting the fan to the motherboard
  9. HP Envy m6-n010dx Fan Replacement: passo 9, immagine 1 di 3 HP Envy m6-n010dx Fan Replacement: passo 9, immagine 2 di 3 HP Envy m6-n010dx Fan Replacement: passo 9, immagine 3 di 3
    • Remove screws indicated in photo.
    • Remove fan
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 961
