Salta al contenuto principale
HP Envy m6-n010dx CPU Replacement
Cosa ti serve
  1. HP Envy m6-n010dx CPU Replacement, Battery: passo 1, immagine 1 di 3 HP Envy m6-n010dx CPU Replacement, Battery: passo 1, immagine 2 di 3 HP Envy m6-n010dx CPU Replacement, Battery: passo 1, immagine 3 di 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx CPU Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx CPU Replacement: passo 3, immagine 1 di 2 HP Envy m6-n010dx CPU Replacement: passo 3, immagine 2 di 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx CPU Replacement: passo 4, immagine 1 di 3 HP Envy m6-n010dx CPU Replacement: passo 4, immagine 2 di 3 HP Envy m6-n010dx CPU Replacement: passo 4, immagine 3 di 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx CPU Replacement, CPU: passo 5, immagine 1 di 3 HP Envy m6-n010dx CPU Replacement, CPU: passo 5, immagine 2 di 3 HP Envy m6-n010dx CPU Replacement, CPU: passo 5, immagine 3 di 3
    • Remove the 6 highlighted 1.5 mm screws using a #00 philips head screwdriver.
    • Pry off the lower two grip pads highlighted in orange.
    • Remove the two additional 1.5mm screws underneath the lower grip pads using a #00 philips head screwdriver.
    • You may need to use more force than feels necessary.
    • Remove the large back panel to reveal the inner workings.
    • The CPU can be found underneath the heatsink, highlighted in yellow.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx CPU Replacement: passo 6, immagine 1 di 3 HP Envy m6-n010dx CPU Replacement: passo 6, immagine 2 di 3 HP Envy m6-n010dx CPU Replacement: passo 6, immagine 3 di 3
    • Loosen the four 1.5 mm screws on the heat sink using a #00 philips head screwdriver.
    • Remove the tape holding the heatsink to the fan.
    • Remove the heatsink.
    • When putting everything back together, use a new strip of electrical tape to make sure the parts are properly secured.
  7. HP Envy m6-n010dx CPU Replacement: passo 7, immagine 1 di 3 HP Envy m6-n010dx CPU Replacement: passo 7, immagine 2 di 3 HP Envy m6-n010dx CPU Replacement: passo 7, immagine 3 di 3
    • Find the uncovered CPU highlighted in red.
    • Turn the fastener, highlighted in orange, 180 degrees counterclockwise using a flat headed screwdriver to loosen the CPU.
  8. HP Envy m6-n010dx CPU Replacement: passo 8, immagine 1 di 3 HP Envy m6-n010dx CPU Replacement: passo 8, immagine 2 di 3 HP Envy m6-n010dx CPU Replacement: passo 8, immagine 3 di 3
    • Gently lift up and remove the CPU
    • Only lift the CPU by the sides, making sure not to touch the bottom, otherwise you may damage your CPU.
    • Don't forget to apply a few drops of thermal paste when putting in a new CPU.
Conclusione
To reassemble your device, follow these instructions in reverse order. Be sure to apply new thermal paste if you are using a new CPU.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,033
