Salta al contenuto principale
HP Envy m6-k022dx Speaker Replacement
Cosa ti serve
  1. HP Envy m6-k022dx Speaker Replacement, Lower Case: passo 1, immagine 1 di 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Speaker Replacement: passo 2, immagine 1 di 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Speaker Replacement: passo 3, immagine 1 di 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Speaker Replacement: passo 4, immagine 1 di 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Remove the two screws holding the speaker in place.
    • There are two red rubber grommets which stay situated in the screw guide holes; be sure not to lose these.
  6. HP Envy m6-k022dx Speaker Replacement: passo 6, immagine 1 di 1
    • Once the screws have been removed, gently lift the speaker straight up, but just enough to dislodge it.
    • There is a cable connecting the speakers to the sound board. Be sure to not tug on this connection when lifting the speaker.
  7. HP Envy m6-k022dx Speaker Replacement: passo 7, immagine 1 di 1
    • Once the speaker is dislodged, gently pull the connecting cable from the sound card.
    • The speaker is now fully removed and ready to be replaced.
Conclusione
Kareem Rigaud
Membro da: 03/02/17
403 Reputazione
3 Guide realizzate
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro di USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 736
