Salta al contenuto principale
HP Envy m6-k022dx RAM Replacement
Cosa ti serve
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: passo 1, immagine 1 di 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: passo 2, immagine 1 di 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: passo 3, immagine 1 di 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: passo 4, immagine 1 di 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: passo 5, immagine 1 di 1
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: passo 6, immagine 1 di 1
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: passo 7, immagine 1 di 1
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro di USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,117
