Salta al contenuto principale
HP Envy m6-k022dx CPU Fan Replacement
Cosa ti serve
  1. HP Envy m6-k022dx CPU Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CPU Fan Replacement: passo 2, immagine 1 di 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CPU Fan Replacement: passo 3, immagine 1 di 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CPU Fan Replacement: passo 4, immagine 1 di 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CPU Fan Replacement, CPU Fan: passo 5, immagine 1 di 1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx CPU Fan Replacement: passo 6, immagine 1 di 1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx CPU Fan Replacement: passo 7, immagine 1 di 1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx CPU Fan Replacement: passo 8, immagine 1 di 1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
Conclusione
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro di USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 804
