Salta al contenuto principale
HP Envy m6-k022dx CMOS Battery Replacement
Cosa ti serve
  1. HP Envy m6-k022dx CMOS Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CMOS Battery Replacement: passo 2, immagine 1 di 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CMOS Battery Replacement: passo 3, immagine 1 di 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CMOS Battery Replacement: passo 4, immagine 1 di 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CMOS Battery Replacement, CMOS Battery: passo 5, immagine 1 di 1
    • There is a power cord connecting the CMOS battery to the motherboard. Disconnect this cord by gently pulling it up, towards the edge of the device.
  6. HP Envy m6-k022dx CMOS Battery Replacement: passo 6, immagine 1 di 1
    • Once the connecting cord has been disconnected, gently lift the battery directly up, above the device.
    • The CMOS battery is now completely removed, and ready to be replaced.
Conclusione
Altre 3 persone hanno completato questa guida.
Kareem Rigaud
Membro da: 03/02/17
403 Reputazione
3 Guide realizzate
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro di USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,861
