Salta al contenuto principale
HP Envy m6-1225dx Optical Drive Replacement
Cosa ti serve
  1. HP Envy m6-1225dx Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx Optical Drive Replacement: passo 2, immagine 1 di 3 HP Envy m6-1225dx Optical Drive Replacement: passo 2, immagine 2 di 3 HP Envy m6-1225dx Optical Drive Replacement: passo 2, immagine 3 di 3
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx Optical Drive Replacement: passo 3, immagine 1 di 1
    • Remove the battery
  4. HP Envy m6-1225dx Optical Drive Replacement: passo 4, immagine 1 di 2 HP Envy m6-1225dx Optical Drive Replacement: passo 4, immagine 2 di 2
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx Optical Drive Replacement: passo 5, immagine 1 di 2 HP Envy m6-1225dx Optical Drive Replacement: passo 5, immagine 2 di 2
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx Optical Drive Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx Optical Drive Replacement: passo 7, immagine 1 di 2 HP Envy m6-1225dx Optical Drive Replacement: passo 7, immagine 2 di 2
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx Optical Drive Replacement: passo 8, immagine 1 di 1
    • Pull the optical drive out of the base of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 178
