Salta al contenuto principale
HP Envy m6-1225dx Cooling Fan Replacement
Cosa ti serve
  1. HP Envy m6-1225dx Cooling Fan Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx Cooling Fan Replacement: passo 2, immagine 1 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 2, immagine 2 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Remove the battery
  4. HP Envy m6-1225dx Cooling Fan Replacement: passo 4, immagine 1 di 2 HP Envy m6-1225dx Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx Cooling Fan Replacement: passo 5, immagine 1 di 2 HP Envy m6-1225dx Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx Cooling Fan Replacement: passo 7, immagine 1 di 2 HP Envy m6-1225dx Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx Cooling Fan Replacement: passo 8, immagine 1 di 1
    • Pull the optical drive out of the base of the laptop.
  9. HP Envy m6-1225dx Cooling Fan Replacement, Cooling Fan: passo 9, immagine 1 di 2 HP Envy m6-1225dx Cooling Fan Replacement, Cooling Fan: passo 9, immagine 2 di 2
    • Remove the four Phillips #1 screws from the hard drive bracket.
  10. HP Envy m6-1225dx Cooling Fan Replacement: passo 10, immagine 1 di 1
    • Disconnect the cable from the side of the hard drive and move to the side.
    • Remove the hard drive.
    • Our laptop did not have a hard drive when we disassembled it
  11. HP Envy m6-1225dx Cooling Fan Replacement: passo 11, immagine 1 di 1
    • Remove the two Phillips #1 screws that secure the keyboard to the laptop.
  12. HP Envy m6-1225dx Cooling Fan Replacement: passo 12, immagine 1 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 12, immagine 2 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 12, immagine 3 di 3
    • Make the device stand onto its left side with the device open.
    • Turn the laptop and look into the empty battery slot for two release holes.
    • Insert a metal spudger into the release holes and apply pressure to the back of the keyboard until it comes loose of the laptop.
  13. HP Envy m6-1225dx Cooling Fan Replacement: passo 13, immagine 1 di 2 HP Envy m6-1225dx Cooling Fan Replacement: passo 13, immagine 2 di 2
    • Gently lift the keyboard away from the laptop.
    • Lift up the cable holder and remove the cable connection from the base of the laptop.
    • Lift up the locking tab of the ZIF connector and remove the keyboard backlight cable.
    • The keyboard backlight cable is only present on select models.
  14. HP Envy m6-1225dx Cooling Fan Replacement: passo 14, immagine 1 di 2 HP Envy m6-1225dx Cooling Fan Replacement: passo 14, immagine 2 di 2
    • Remove the 13 screws on the bottom of the laptop that secure the top cover using a Phillips #1 screwdriver.
  15. HP Envy m6-1225dx Cooling Fan Replacement: passo 15, immagine 1 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 15, immagine 2 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 15, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect Power button board cable using a pair tweezers.
    • Disconnect Touch Pad button board cable using a pair tweezers.
    • Disconnect Fingerprint reader board cable using a pair tweezers.
    • Disconnect Right speaker cable using a pair tweezers.
    • Remove the 4 screws using a Phillips #1 screwdriver.
    • Apply force to the base of the cover to pop if off from the laptop base.
    • Be sure the cable for the right speaker doesn't get caught on the cover as it is removed or the speaker could be damaged.
  16. HP Envy m6-1225dx Cooling Fan Replacement: passo 16, immagine 1 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 16, immagine 2 di 3 HP Envy m6-1225dx Cooling Fan Replacement: passo 16, immagine 3 di 3
    • Remove the two screws holding the cooling fan down with a Phillips #1 screwdriver.
    • Disconnect the cooling fan cable using a pair tweezers.
    • Gently lift the cooling fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 301
