Introduzione
In this repair guide, you will be learning how to re-seat or replace the memory modules in your HP Envy m6-1105dx. For this repair, the only tool you will need is a screwdriver. You will loosen a screw and remove a piece of the plastic casing in order to access the memory module. Don't worry when you can't take out the screw, it doesn't actually come out. To remove the module, simply apply pressure to the levers holding the memory module in place and lift it out.
Turn the computer completely off.
Disconnect any devices you have on it.
Turn the computer upside down on a flat surface.
Release the screw in the center of the service cover.
Slide the battery release latch and pull cover towards you.
Lift cover off.
