Salta al contenuto principale
HP Envy dv7t-7200 Optical Disc Drive Replacement
Cosa ti serve
  1. HP Envy dv7t-7200 Optical Disc Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 2, immagine 1 di 3 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 2, immagine 2 di 3 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 2, immagine 3 di 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 3, immagine 1 di 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Optical Disc Drive Replacement, Service Cover: passo 4, immagine 1 di 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 5, immagine 1 di 2 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 5, immagine 2 di 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Optical Disc Drive Replacement, Optical Disc Drive: passo 6, immagine 1 di 1
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 7, immagine 1 di 2 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 7, immagine 2 di 2
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 8, immagine 1 di 2 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 8, immagine 2 di 2
    • Slide the disk drive out of the laptop.
Conclusione
Krystal
Membro da: 10/16/17
882 Reputazione
8 Guide realizzate
UW Tacoma, Team S3-G3, Liner Fall 2017 Membro di UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 135
