Salta al contenuto principale
HP Envy Ultrabook 4-1043cl RAM Replacement
Cosa ti serve
  1. HP Envy Ultrabook 4-1043cl RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl RAM Replacement: passo 2, immagine 1 di 2 HP Envy Ultrabook 4-1043cl RAM Replacement: passo 2, immagine 2 di 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl RAM Replacement: passo 3, immagine 1 di 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl RAM Replacement: passo 4, immagine 1 di 2 HP Envy Ultrabook 4-1043cl RAM Replacement: passo 4, immagine 2 di 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl RAM Replacement: passo 5, immagine 1 di 2 HP Envy Ultrabook 4-1043cl RAM Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: passo 6, immagine 1 di 3 HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: passo 6, immagine 2 di 3 HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: passo 6, immagine 3 di 3
    • The RAM lies in the middle-right side of the device.
    • Use your fingers and push the two clips outwards to release the RAM stick.
  7. HP Envy Ultrabook 4-1043cl RAM Replacement: passo 7, immagine 1 di 1
    • Remove the RAM from the device.
  8. HP Envy Ultrabook 4-1043cl RAM Replacement: passo 8, immagine 1 di 3 HP Envy Ultrabook 4-1043cl RAM Replacement: passo 8, immagine 2 di 3 HP Envy Ultrabook 4-1043cl RAM Replacement: passo 8, immagine 3 di 3
    • Repeat the previous two steps to remove any other RAM sticks.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 356
