Salta al contenuto principale
HP Envy Touchsmart m6-k125dx Touch Screen Replacement
Cosa ti serve
  1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement, Touch Screen: passo 1, immagine 1 di 1
    • Open the laptop.
    • Remove black tabs at bottom left and right corners and remove the two M2.5x2.5 screws behind the black tabs with the J0 screwdriver.
  2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 2, immagine 1 di 2 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 2, immagine 2 di 2
    • Insert pick between the black plastic screen panel and the silver plastic exterior case on the side of the device.
    • Slide pick around the border of the screen panel while keeping the pick between the mentioned panel and exterior case.
    • Repeat previous two steps until exterior case is removed. Pry with minimal force if necessary.
  3. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 3, immagine 1 di 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 3, immagine 2 di 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 3, immagine 3 di 3
    • Remove the front panel from the rest of the device and set it aside.
    • Remove the ten M2.5x2.5 screws with the J0 screwdriver.
    • Remove the eight M2.0x2.0 screws with the J0 screwdriver.
  4. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 4, immagine 1 di 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 4, immagine 2 di 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 4, immagine 3 di 3
    • Flip hinges down and away from the rest of the panel.
    • Remove the four M2.5x2.5 screws with the J0 screwdriver.
    • Move 4 pieces of black tape across the bottom of the panel and any other accessory tape.
    • Disconnect the display cable connector that is located at the bottom right of the panel by pulling lightly.
  5. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: passo 5, immagine 1 di 1
    • Slowly lift the screen away from the touch screen front panel to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S14-G14, Wilson Spring 2019 Membro di IUPUI, Team S14-G14, Wilson Spring 2019
IUPUI-WILSON-S19S14G14
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 868
